any one ever seen this AA part #
timmy ray
Hi I have a trans/low gear part #s on it are A4514B///pfg-2-B////A4835//
AA-1902-B ////It is round flat bottom, 2 FT long with input and output {A} Splines. a foot peddle that goes in the floor that you shift with your foot And has ford markings on it can any one help please:)
Sound like a Dual High.
Bob
The dual high (actually a misnomer as it's actually a dual low) varies in the marketplace. There are a fair number of these floating around - mostly from farm trucks which - unless the owner wants to plow a field or something with the truck - usually never use and possibly remove the dual high. And there are a fair amount of "barn finds" and chassis' that are found with the dual high.
I might even say it's harder to find the "intermediate shaft" complete and you will probably pay more for this than you will for the dual high you might want to replace "straight through."
I watched them for a while on Ebay and I've seen them sell for as little as $64, and as much as $364.
Some (including myself) have contemplated that it should be possible to modify the dual high and turn it end for end and make themselves a REAL dual high - as in an overdrive unit. But I have not seen this done and I imagine the machine work/modification to the case might be extensive.
Most go for a warford, or a mitchell to get the overdrive on their AA truck (and keep up with modern traffic).
Joe K
Joe K
So what are you talking for speed with a Warford or Mitchell in the AA with a 5:14 to 1 rear end? Is there a Mitchell made for the AA?
IIRC, the AA truck with a Warford or a specially constructed Mitchell set up on the intermediate shaft yields an AA speed comfortably between 55 and 60. Similar certainly to the Model A automobile without an overdrive.
There is a mitchell unit made to directly replace the intermediate shaft on the AA truck.
The mitchell units were like $1400 - but were basically "plug & play" with Mitchell giving you all the necessary components - including the U-joints necessary to make it happen.
Warfords tend to go in the price range of $600 to $850 (I think I sold mine to the buyer of the AA chassis I sold for $675) and I had already solved the problems of the U-joint transformations. You need to have TWO U-joints adapted to the Warford on one side (6 point spline) and the AA axle on the other (like an 11 point spline -forget exactly what it is - but new parts in both conventions are available infrequently from Dana/Spicer who make these things on "as stock required" basis.)
The thing about the Dual high AND the AA Warford is that both were derived from the Model A 3 speed transmission and is adapted to that AND the Model AA truck worm gear rear end directly. When Ford "re-engineered" the AA truck to include Borg-Warner 4 speed and the AA bevel gear rear, Ford didn't at first make the parts 'back-fit-able." Only later during the years of the Ford "Green Book" (Chassis Interchange & parts) were cross connection and backfit possibilities identified.
I was fortunate on the two U-Joints. Tam (of Tam's Model A) helped me get the first "transition" U-joint. Finding that worked, it became the model for me to examine ALL the U-Joints I could find at Amherst - until I found parts of one and parts of another that I could make up into the second unit (in their size range, the parts are all interchangeable based on the cross - the yokes vary only in the details of the spline.)
Hope this helps. I think I know where you're going.
Joe K
The Mitchell I saw for the AA goes in the torque tube just like the Model A.
Picture belongs to 31 SWFL.
Bob
I confess I have not looked at Mitchell's offerings since 2010. No doubt there is more than one way to do it.
Maybe best would be a mitchell ****** with (now your choice of ratio) overdrive?
Heh. One could have overdrive AND dual high. Chasing one's tail?
Joe K
