First off a Big Thanks to Charlie NY for the PV gaskets and your truck is Gawgis! Looks like a Bubba's dizzy on there.
Well the following is what I did and where I am at:
I went through valve adjustment since the intake was off, some were as far as .010
loose and a few were a couple thousands tight. I set all the intakes at .012 and exhaust at .014. I replaced intake gasket with a coat of gasgacinch. I went through both carbs checking everything and even removed discharge nozzles. Still do not quite understand when they say to check the nozzles for damaged holes from over-tightening of main jets. All 5 holes were fine along the tube. Anyway once I had everything back together except for the tops of carbs I ran the fuel pump and gauge was showing 2.5 psi then all of a sudden it shot up to 4 psi. Hmmm, installed pressure regulator which say it adjust from 1-4 ps. Never could achieve 1-1.5 psi even had adjuster screw all the way out hovers around 2 psi, Bored & Stroked curious which fuel regulator do you use? Anyway fairly happy with fuel pressure, floats are set at 1/2" but I noticed front carb the level was higher. Adjusted tang on float, it would still rise slowly. These carbs came with S-Jet inlet valves. So I put another one in and same thing. I finally gave up on it and put a regular needle and seat in it and presto no more rising fuel. Current configuration is 69 PV's and 42 mains. Starts up and idles better than ever @ 500 rpm, throttle no load sounds good. Test drive lacking fuel on acceleration, falls on it's face. I can feather it and keep it rolling on down the road, going from S setting to W helped somewhat but not quite there. Carbs uni-synced just fine. Idle jets 1 turn out. vacuum at idle bounces 9-10 rev it up 1500-2000 rpm and it climbs and steady around 20. Not sure how accurate vacuum is due to the only provision on the intake pulls at #5 or #8 intake port. Not sure what you guys think but Maybe I should try the 43 mains and give her another run? Thanks Gary
