Brian SATX Well-known member Feb 8, 2016 #1 It says "MFG for Ford Dealer Supply" and "By Alamo iron Works, San Antonio, Texas" on it Attachments IMG_20160208_112752.jpg 65.5 KB · Views: 168 IMG_20160208_112809.jpg 80.5 KB · Views: 191 IMG_20160208_112826.jpg 86.7 KB · Views: 181 IMG_20160208_112925.jpg 68.6 KB · Views: 144
B Bob C Well-known member Feb 8, 2016 #2 How big is it? Is that black on the outside rubber? Not knowing the size it almost looks like a front wheel for an old warehouse tug. Bob
SeaSlugs Well-known member Feb 8, 2016 #4 bdave_mcc said: Tractor wheel weight? Click to expand... would be my guess too, the outer holes are way to far apart for a tug or machine cart or something.
Bill Cilker Senior Member Feb 8, 2016 #5 A front wheel for a Fordson? The center hole has tapered roller bearing races in it.
B Bob C Well-known member Feb 8, 2016 #6 Maybe something like this. Bob Attachments tug.jpg 115.1 KB · Views: 166
I Indiana A. Lover Senior Member Feb 8, 2016 #8 I got nosey and looked up Alamo Iron Works in San Antonio Texas look it up pretty good read
Tom Wesenberg Well-known member Feb 8, 2016 #9 Bill Cilker said: A front wheel for a Fordson? The center hole has tapered roller bearing races in it. Click to expand... At first I was thinking a wheel for a factory supply parts cart, but I think Bill might be right, and the 4 holes are used to bolt on wheel weights.
Mike V. Florida Well-known member Feb 8, 2016 #10 I think they are still in business, try sending them the pick and see if you can get an answer form the source. 943 AT&T Center Parkway San Antonio, TX 78219 Phone: 210.223.6161 Toll-free: 800.292.7817 Fax: 210.704.8351
bdave_mcc Senior Member Feb 9, 2016 #11 I did a few google searches and found some old forklifts and tractors that had this type wheel/hub assembly but nothing ford related
Bill Cilker Senior Member Feb 9, 2016 #13 The more I think about it, I think that Bader is correct. It is probably for a piece of Ag equipment that Ford built to work with the Fordson
