Gosh you're right ... not just misleading .... it's WRONG!.. so sad that inaccurate diagrams/advice like that gets repeated so easily these days .The diagram of the coil internal electrics in the Hemmings article is misleading. ....
The diagram of the coil internal electrics in the Hemmings article is misleading. It shows the secondary coil being grounded on one end with the other end to the high tension terminal. This is misleading. The secondary coil actually connects to one side of the primary coil near a terminal. They were generally connected to the negative side connection but this is why a polarity tester is needed. Since a person can't see inside, they wouldn't know which terminal it may be connected in with. They would never ground it through the case like that diagram implies.
Good Morning...Why not just order the correct coil from Bratton's or Bert's, Snyder's or Arizona Model A, and be sure you have the correct one. Also we need to keep the suppliers in business as they have a mutual interest in stocking what we need and the modern suppliers do not. Ernie in Arizona
Because it's for a Roadster 'hop up' from the 40's. Trying to preserve what we can, and replace with period parts that were used.
Don't worry, we're giving those vendors (and more) plenty of business
Sorry Purdy, I didn't read any of the posts. Didn't have the time. Had I read yours I wouldn't have responded.
did a little more reading and I see now where an automotive coil is an autotransformer
