Afordman31
Rumor that they are going out of business the end of the year! Anyone else heard that?
Does that jeopardise the availability of his insert rod beatings?
IF you're going to need them, NOW is the time to buy. JMO
Paul in CT
Let me get this straight. So the rods and bearings sold by the likes of Snyders are made by Rich and is he the maker of the main bearing inserts for the likes of the Burlington or Scat crank shafts?
If yes to the above, I assume I can buy direct from him. Yes/no?
SYNCHRO, I have Snyders rods and inserts in my roadster. They are not from AER. The inserts have side thrust walls, imitating the original Ford rod Babbitt. AER inserts do not.
I don't know if this is a good thing or not, since most common modern shells do not incorporate side thrusts.
SAJ in NZ
