antifreeze
franksford
Any thoughts on the best product to cut down on corrosion to aluminum heads. I have an anode and antifreeze installed but that may not be enough. There several antifreeze's available, all claiming to be the best at something???? What are you using?
Thanks
A high percentage of modern engines have aluminum heads, water pumps, ect, there are several brand/types especially formulated for this mixed metal environment.
What J Seery says there are thousands of bi metal engines in today's cars use their antifreeze. You will have no worries.
R
