antifreeze?
FrankWest
Any good sources for Antifreeze-Coolant Propylene Glycol
Seems harder and harder to find.
Should I just use everyday antifreeze? Or does that really corrode the bearings?
Walmart has the Propylene Glycol (the green stuff). Well at least for now. It may be totally outlawed in the future depending on who will be running things.
QMDV,
I live in Massachusetts, and that post resonates a little too close to home. Went to the local Wally's a few months ago, and was shocked to pay $20.00 for two gallons of antifreeze. State DEP put a new tax on it. Thanks Granny Warren!
A little off topic but, does antifreeze have a shelf life? I have a couple of gallons that have been sitting on shelf for several years.
In a 1933 model B or a 1933 v8 engine are 5 gallons proper coolant fill? or should 4.5 gallons be used because over overfill/runnoff?
antifreeze actually does have a shelf life...sorta, in the big trucks they test it with some paper strips of some sort because it will get corrosive after 5 years or so. not sure if its from all the heating and cooling cycles, or a real shelf life.
They have so many kinds on the shelf I'm about ready to go back to alcohol. 4 cars in garage, 3 of them Fords and 4 different requirements for antifreeze. Then you go to buy some and they sell gallons of "works in everything".
It is a bit confusing with how many colours of anti freeze there are now. Besides the old green, I have some red, some yellow. Some recommended for diesel engines. On light duty gas engines I've been using "recycled" anti freeze that I have changed out of my diesel engines. Left to settle and filtered several times it looks pretty good and still tests food for our severe cold winters.
just an aside the strips mentioned can be purchased at a swimming pool supply store.they are used to check pool PH works for anti freeze as well
Regarding shelf life, I'm not sure about the anti corrosion properties but I recently drained the antifreeze out of a boat engine that was winterized 20 years ago. It was clean, still bright green and tested at -50F.
