ModAfan
I sent the questions below to Prestone recently. The company’s reply follows. Any thoughts or comments?
My Questions to Prestone:
I have a 1928 Ford Model A. It has no coolant reservoir, no heater and
its cooling system is not pressurized. When it overheats, it just
blows its top. (My car has not overheated, yet.) Its four-cylinder
engine is cast iron.
Q1: Can I, or should I, use AS105 Radiator Flush in the Model A's
cooling system?
Q2: You have several kinds of antifreeze - Extended Life, Dex-cool and
Low-Tox to mention a few. Which one would you recommend for my
87-year-old Model A?
Answer:
I do not foresee any problems with using the Prestone Radiator Flush + Cleaner in that application, however I cannot expressly endorse its use due to a lack of familiarity with the exact materials used in cooling systems of that vintage. Personally, I would recommend the Prestone LowTox for use in that vehicle for two reasons:
First, it uses a conventional silicated corrosion inhibitor package that is better suited for an unpressurized, open cooling system than modern extended life formulations.
Second, it is based on propylene glycol which is far less toxic to pets and wildlife than the ethylene glycol used in regular antifreeze, thus there is less ecological concern if the vehicle happens to boil over.
Please be sure to flush the system with water thoroughly to remove any EG-based antifreeze prior to switching the vehicle over to the Prestone LowTox. Please let me know if you require anything further.
Sincerely,
Prestone Consumer Relations
cooling system?
Answer:
Sincerely,
