Anti Theft Devices You Can Install
There may be an add-on automotive security system with the shut-down 'distance' function built in.
Hmmmm. Many...So far I find 1 that looks like it's had some thought behind it, and works on a non-computer car. It does have a subscription fee though.
Run the car on an electric fuel pump with a toggle switch in an easy to reach but slightly out of sight position. The car will likely go a block or so on the gas in the fuel bowl.
My daily driver has keyless ignition, as long as the key fob is within a couple feet of the dashboard.
An aftermarket electronic automotive alarm system may(?) be able to shut the ignition down after it gets a certain distance away from the small remote in your pocket.
Like the electric pump and cutoff switch.
In 1970 I bought a low mileage 1968 used car. Daily driver, red sports car. Under the dash I found an odd plastic affair with a slow blow fuse in it. Pushed in the car ran. Pulled out to the first stop the car started, ran about 10 seconds and blew the fuse. Pull all the way out you could change the fuse. I figured the original owner had put it in as an anti theft device. Took me a while to find the replacement fuse.
In college I parked in a large lot with minimal security. I fitted a fuel shut off controlled by a cable, and pulled a matching cable out of junkyard to operate it. The car would start, leave the lot, and be a block away when it stuttered and died on an alway busy 4 lane road. I figured it might get towed, but at least I’d get it back.
This was before thieves used trailers and tow trucks.
A bumper sticker I saw recently: "The driver of this vehicle is armed 3 days a week. You pick the days."
when we were traveling a lot I installed a horn, hidden in our '41, that went off if anyone opened the hood or any door. reset switch was in the trunk. just had to remember to turn the switch off before I unlocked & opened the doors.
How about a trunk monkey?
I had one of those monkeys in a 57 RANCHERO. The car was stolen and subject to a police chase. Thief ran off the road and into a river. When they pulled the car out, they found both the driver and monkey dead, the driver of blunt force trauma and the monkey was laying in the bed.
Coroner surmised the monkey drowned as he could not figure out how to open the tailgate and escape.
And to top it all off, the company would not grant me a refund ... :cool:
I have an electrical disconnect and a fuel shut off switch that I installed for maintenance purposes without thinking about those being theft deterrent devices but they certainly are........
I installed an electric fuel pump in my 57 T Bird by the gas tank. I then hid the on off switch. Then I removed the guts from the fuel part of the mechanical fuel pump and left the vacuum pump part for the wipers in place. The factory pump is just a pass through for the electric pump. I turn off the electric pump and it will start and run until the carb runs dry. I also turn the pump off and let the carb run dry when storing it any length of time. Saves a lot of carb problems.
I don't I'd even want to drive my car again with something like this.
You have your stuff in a neat pile ... ;)
"If someone points a gun at me, I would not hesitate to use the method in the 1st video."
It's legal in S. Africa but I doubt it would be legal anywhere in the U.S., plus they wisely don't have the legal tort system we have. I can just imagine the lawsuits here if somebody rigged one up and used it.
Near as I can tell, from a search, is that flamethrowers
are legal on vehicles in every state, except California.
The flame thrower is really something. I am a burn survivor. I had 2nd and 3rd degree burns over 28 - 35% of my body, and was in the burn ward for some time. I can tell you, if they survive that will be the last carjacking they ever attempt. 14 years ago and I still am applying topical cream daily. Those places on a persons skin that look like melted plastic are a constant reminder.
Where I live the government would lock me up, and sue me.
