Walt Dupont--Me.
This 59AB is going in a 35 pickup. 276ci, max-1 cam, You can see the rest. Another good street engine. Walt
D.Jones. Those are Chevy valves, same head dia. 1-1/2in as the Ford. They just look close in the pic. WaltWalt,
What size are the valves. Looks like they almost touch in the center.
Saw an 8BA block with valves like that Sunday when I bought some parts from another Barner. The guy said the motor came from a drag car and put out 475 HP. Had some super special crank with 4 7/16 " throw and had been bored to the max.
OOOOOOOH no. I'm going to run out in the shop and check it. LOL If you go back a few weeks you'll find a long thread on this same subject. You can see that plate I made for the back of the block and the stand bolts to the plate. BUT, I've built 100's of flatheads and never used a plate until about 10yr's ago. Accually how many flatheads have you seen with broken bellhousings. I saw a pic of one once and if the trough be known, chances are the bolt weren't long enough or bolted up tight. I don't want to tell anybody how to mount there engine. WaltI thought you were not supposed to mount an early flathead like that??
Walt beautiful work. I'm curious how do you arrive at 276 Cu.In? I assume you use a 4" crank. What is the bore size? This is referring to an 8 BA block.
Thank you!
