Another Valve Question
Joe AZ
I posted a question a couple of weeks ago regarding pulling the valves from my '40 block. It appeared that I had mushroom style valves, but they turned out to be '51-'53 valves.
My question is this: Every piece of literature I have on flatheads lists the valve stem diameter as .3115. My valves are checking out at .340.
Were the later valve stems a larger diameter?
Thanks, Joe
Going by your photo, you've got the later valve rotators. Valves, whilst appearing the same, actually have the keeper groove in a slightly different location to standard 8BA valves; still 11/32" dia stems though as Ronnie said
