Another standard roadster top question!!
JRShaw
Gentlemen: I have enclosed a couple of pictures that show the side links which connect to the back of the top irons. There are pins just to the right of my labels. The pin is about .255/.260" in diameter withe an almost spherical end. The height of the pin is about .300/.310" tall. QUESTION: Do these pins remain in the top when it is being closed?? A friend told me that the pins are to be pulled out when closing the top. Thank You in Advance!!
Joel R. Shaw
Fairport, N.Y.
Do you know of someone that makes the top bows for the 30 standard roadster? If not, could you take the measurements of the bows so that i can try to make a set.
Thanks,
Jesse
