Dyna
I have a 1948 Merc 114. When I purchased the car the previous owner had replaced the original shocks with tube shocks. The front ones are fine but the rear ones are a problem. The rear bottoms out when I drive over any small bump. The upper end of the shockis mounted to a bracket on the side of the frame, the lower end is mounted to the end of the axle tube just above the spring shackle. I need to lower the lower mount in order to give the shock enough travel to avoid hitting the frame. My plan is to attach the lower end of the shock to the lower bolt of the spring shackle and gain about four inches of travel for the shock. My question is: if I raise the rear end and take the weight of the car off the spring will I be able to take out the lower shackle bolt without any energy being released from the spring and avoid a catastrophe. Any ideas appreciated. The shocks I have are new, oil filled. Greg
