Problem: No spark
Basic data:
1940 Ford COE
1946-49 "59AB" V8 flathead engine
all original except for wiring completely redone and electric fuel pump addeded
6 volt, positive ground
truck was last run and driven for a short distance (approx 200 feet) approximately 13 years ago
Ignition data:
Rebuilt stock carburator
Helmet distributor
Fuel tank cleaned and fresh fuel added
all new fuel lines and filter
new condenser
new points
new distributor caps
new spark plug wires
new spark plugs
stock ignition resistor
Symtoms:
With battery connected and ignition switch on:
6v at ignition switch
6v at input side of resistor
6v at output side of resistor (may I assume this will drop while motor is being cranked?)
6v at input to coil
Engine cranks but doesn't catch.
Pulled a plug, reconnected wire, held against clean ground and cranked engine. No spark
If you feel it might be the condenser and/or the coil (as I do), could you please give me DETAILED testing procedures as I've never attempted anything like this before.
Thanks!
Basic data:
1940 Ford COE
Ignition data:
Helmet distributor
new condenser
new points
new spark plugs
Symtoms:
6v at input to coil
Thanks!
