PaintShaker
So I went to install my new horn rod. I can't even come close to getting it started down the bore in the steering column. There's quite a buildup of rust in the bore. I'm not sure yet how far down the rust goes. I need to increase the ID by about .030 in. to get a few thousandths clearance for the rod. Is the bore the same diameter all the way down, or might there be a step? It's very hard to see. I may be able to clean up the bore for 2 or 3 inches by running a drill bit down there. A cruder approach would be a dowel wrapped in emery paper, but beyond that I'm out of ideas. I'm hoping the only solution isn't throwing out the part and starting over. I would appreciate any suggestions. Thanks.
