Coneross-A
I have been looking over some of the threads on polarizing generators, and I'm not clear on the whole procedure.
At some point my "A" was converted to negative ground. I want to go back to positive ground. So as I understand it, the first step is to put a jumper across the leads on the cutout for 1 second or so while the engine is running. I assume that the next step would be to shut the engine down and switch the battery leads? Also...the ammeter wires would have to be switched and to the coil.
Am I missing any thing? Any help would be much appreciated.
