Jemelton#
I have been noticing that my ammeter is indicating a 10 amp charge whenever the motor rpm is slightly above idle. It never seems to drop to a lower value as it should when the battery is charged.
As most of my trips are less than 20 miles or so, I have been ignoring the problem.
Is it a likely a defective cut-out? If so, is the diode type the way to go, or should I get inside the original cut-out and try to fix it.
The generator is an original 6V type and the battery is less than a year old
