Blownflatheaddeuce
Good to see it was sorted by Clive and you're up and running !
I must be lucky with the modded crab with 12V Pertronix I put together 10 yrs ago. Still going strong !
No to hijack, I just buttoned up a buddy's 59A and he wanted an E Fire so will be looking to fire it soon but want to confirm the correct coil resistance.
Similar to Pertronix, the right coil is paramount as are spiral core wires and engine grounds etc. I've been advised the coil needs to be 1.5 Ohms without a ballast resistor or 3 Ohms if you run the ballast resistor.
Sound logical enough, can anyone confirm to be sure?
