DeBordEngineMan
Hey guys I have ordered just about all new brake parts for the 29 Tudor I ordered cast drums from Mel Gross should be in this week and the rest from Bratton's and a local clutch and brake relining shop are doing my shoes with the same linings that a Model A restorer in the area uses but I did not get new hubs going to use my old ones, the problem is my studs have been welded to the hubs I was going to leave them alone like they are and install drums I know that is not correct way to do but if I grind the studs off from behind (Randy, Me'ls son said you could do that) I might ruin the hubs. Looks like they have been welded down in the recesses where the stud seats on hub and I am afraid they may pull threw the hub when swedged ? Not sure? I am having more trouble with the brakes than any other part of the car so far. Can I run the drums on the welded studs? I was going to grind the hubs down in back and remove studs and get new studs and have them swedged like they are suppose to be until I saw how they were welded. Can I safely run the drums on these hubs like they are(welded) until I can afford new hubs? Are the old studs long enough to work "if" you can run the drums this way seeing that the new drums are thicker? The two front hubs I can grind off pretty easy and do them right but the back studs look like that the studs are flatter on the back side of the drum than the front and this where the weld looks like it is in were the stud seats to the hub. Sorry for so many repeated posts about the brakes. Thanks, Robert DeBord
