First, thank you to those who responded to my earlier clutch question. I now have a better perspective of the machining required.
My next question is: What is the reason for the following statement from the Bratton's catalog (in bold & underlined)? - V-8 PRESSURE PLATE - Helps reduce the amount of pressure needed to depress the clutch pedal by about 2/3rds. To use this, the crank must be counterbalanced and the flywheel must be machined. No changes in the way the clutch pedal is adjusted.
Are there A'ers out there who have used the V8 clutch without a counterbalanced crank? If so, what were your results?
