Do I need to keep the 3 degrees?
The reason that I ask this because I have a model T chassis that I has been lying around and I have some spare model A parts.
I am building a brass era speedster with model A running gear.
So I will be making engine supports for the model A engine.
The engine's angle coincides withe angle of the drive shaft and differential. The idea is to have a static straight line from the pinion gear to the crankshaft.
I think that you also need the angle to help fill the rear of the valve chamber to supply the rear main with oil. Sitting level just the front part of the chamber will fill then start spilling over on the timing gears
Might also help with venting of the cooling system, eliminating trapped air that would become steam pockets
