Chuck Sea/Tac
I remember seeing an ad for making the line duty connection to the sw terminal “button” a proper connection, but don’t remember where, or how it was designed?
You say it was working good before you worked on it.I really doubt the starter decided to go bad at the exact time you were working on it.Shotgunning parts at it,(battery,starter,etc)isn't the answer.If you checked all your connections,cables and switch 5 times,you need to check them 6.Something you touched is a little off,even if it all looks perfect.
