amp reads backward?
DENY 411
car was sitting for 2 yrs. Now it starts and runs , The amp meter shows adischard when engine is running. When swich is off turn rhe lights on and it shows a charge. Not a discharge. I am confused!
How is the battery connected? — originally the car is positive ground.
If it was and the battery is put in negative ground the ammeter will work backwards
The battery is correct. As car was sitting 3 people were working on it at the same time,
not sure what all was done to it! IT does start and run, and the amp meter used to work correctly.
If the battey in it positive to ground, then just swap the wires on the amp mete - problem solved.
If your electrical system is using positrons instead of electrons then the meter will read backwards.
update:thankyoukurt in NJ Ruth, and Gene F--I pulled IP amp meter was not touched the Ing swich was wires had been swiched (Not orininal style) I swiched them back making sure not to let it short out agin. Everything fine!
