mngreen
I've had a 12V Delco alternator with regulator setup running in my Model A without an ammeter connected for the last 35 years. I decided last month to connect the ammeter for the first time. It shows about a 20 amp charge right after startup then decreases to near zero as a correct charging circuit should. It shows a charge to compensate when turning on headlights, etc. while running, so it mostly seems okay. However...
But then sometimes the meter intermittently fluctuates wildly at certain RPMs and then evens out at speed.
Anything that I should be concerned about? I have the circuit fused.
Thanks.
Thanks.
