The powerhouse has a screw that must be loosened to adjust the third brush, but the common long generator third brush is held down by two tension springs, so no screws need to be touched, except the band screw. If the adjustable brush hasen't been moved for a long time it is usually very stiff, so I like to break it loose with a screwdriver while the engine is off.
