Black wire? One wire to the ammeter should be yellow and the other one yellow with a black tracer. Is this a put-together wiring harness? Or are you asking about the (probable) black wire running from the instrument panel light? That can go to either side of the ammeter for power, as I recall.
Marshall
If the car is wired as a stock 6 volt, positive ground:
Yellow / black tracer to the "Charge" side. (as written on the front of the ammeter)
Yellow to the "Discharge" side.
I suggest you make certain that your black wire to the - negative side of the coil is sourced from the yellow / black tracer from the generator / alternator side of the terminal box as per the November, 1929 service bulletin suggests.
Great advice. Thank you. That's how I had it and now can rest calmly![]()
