joltesvig
Should the ammeter needle move slightly negative when I turn the ignition switch on indicating the ignition switch is making contact?
When cranking the engine should the ammeter needle make a large move toward discharge?
If I am charging the battery with battery charger, should the ammeter needle show a large move toward right side?
I don’t know if my ammeter is not working or if the ignition switch is not making contact?
Is there an way to check without any disassembly?
