fordfun
I noticed some rust bubbles inside the horn bell and decided to deal with it before it got much worse. That lead to stripping the paint off of the exposed components and then giving them a soak in Evapo-rust followed by some wire brushing. This revealed the Ames ID markings on several of the pieces. I thought the following photos might be of interest.
I found the most severe rust on the external face of the diaphragm. After the Evapo-rust soak, I polished this with some light emery cloth rather than using the wire brush, as others have suggested. However, the surface is pitted and I'm wondering whether to reuse this or install a replacement? If I were to reuse it, would a light coat of grease retard further rust or should it be painted? I see that the replacements are painted.
Thanks - Bill
Thanks - Bill
