Always Learning
mountinpie
It's amazing how much we can learn from each other just by reading miscellaneous posts. After reading a post from Blockhead called "Sometimes..." I realized that I have this light bar on the shelf. While I haven't starting thinking about the light bar, my plan was to use the cast light bar, rather than the stamped one, just because it looked more original. Thanks for saving me from making that mistake. This light bar is cracked on one side and previously repaired on the other, but worth saving, right?
Very rare piece there. Only used for June til September of 30 or there abouts. I would fix it and use it if it's correct for your car
Bob C suggested in a post earlier this year that it was used May to August 1930. The car is late-May. Can anyone else confirm the dates these bars were used?
That could be correct. I'm going off memory. It's listed in the judging standards
Post # 1: "This light bar is cracked on one side and previously repaired on the other."
- Makes it easy to see why Ford dropped this design and replaced it with a heftier designed headlite bar.
