'Beats me why someone went to all the trouble and investment of making Model A radiators out of aluminum, but didn't bother measuring where the water inlet and outlet necks go or put at the correct angle. The main culprit is the filler neck being at least 1/2" off center so that the radiator shell cannot be lowered over the radiator without altering the shell itself (Gasp!!!). I understand that the side brackets where the shell bolts to are also not where they belong. What else is left to be incorrect??? Yes, they do cool efficiently, but what good does that do when you can't put on the shell, the hood doesn't fit, the water necks are at the wrong angle and the filler neck is misplaced? These aluminum radiators have been on the market for years now. Don't you think the manufacturer would have made corrections by now???
Marshall
