aluminum intake
flatheadA
I am putting a fenton 4 barrel intake on my flaty,does any body the torque specs,also is there a patern I should use.
just a little bit of info, aluminum manifolds run hot, and transfer that heat to the carb, thus causing the fuel to boil out, put a least a half inch fiber spacer under carb, a thicker one if you have room, an inch thick is a lot better
