aluminum head
harryc
Is anyone making a relatively low compression (6:1) or less aluminum head ? of any style? Cast iron heads are getting to be too much for the back at my current state.-------thanks
How often are you removing heads? You could always use an engine hoist to remove them and move them to a work bench or at least chest high for optimal carrying.
I have wanted to up the compression on my stock A speedster, but I am worried about knocking the bottom end out of it.
wow, just went through all those speed websites and I want my wife to ignore the debit card bill for a while
It's not high compression that causes babbitt problems, it is detonation. I ran a 7.4:1 Cyclone head for years with no problems.
Is there a stock looking aluminum head being made?
Also, do any of the heads mentioned above use stock sized plugs?
In the 60's and 70's I ran an original Thomas 8.25 aluminum head on an old worn out babbitt Model A engine.
Dwayne Helms here in Denver runs a 12.0 to 1 Cooke head on a babbitt engine.
Why? is your engine tired?
well ive not had the bottom end apart but it runs smooth and fine doesn't burn oil makes no knocking sounds
I was under the impression that higher comp was very hard on the bearings so haven't done it would like to however
the reason I specified 6:1 or less was to maybe reduce oil consumption. I really don't know but it would seem that a higher compression would tend to inhale more oil past the rings on the intake stroke-- that was my thought anyway.
I would think tht would make no difference at all compression has nothing to do with the intake stroke while the valve is open
