In addition, I always use 'Red Loctite' . . . makes me feel a bit better about everything. The original bolts were drilled for a tie-wire, so if you have them . . . use them (if they engage to the proper depth).
The thickness of various flywheels (in the bolt flange) can differ - and in many cases the aluminum ones are thicker in the flange - so, think about this and make sure that your bolts are the correct length to engage with the crankshaft as they should . . . which is pretty much through the entire crankshaft flange thickness.
Pressure Plate Bolts: It is kind of the same deal, make sure you use 'shoulder bolts' - that are designed to go down into the flywheel and index as such. There are many different type of clutch bolts - make sure that what you use are correct for the pressure plate as well as the flywheel.
In the end, when you are using non-stock parts, it is up to you to figure out the details . . . just the way it is.
Good luck . . .
B&S
