Good advice from dmsfrr above, no need to change anything, the 6v system is fine when all items are in good working order. There have been many threads about the gear drive starters failing over on the hamb. I do have a 6v alternator on one of my model A's as I drive that car all year around, and often in the dark. My Christmas treat to myself last week was a cruise in the A at about 6 above zero, light snow, about 30 miles of gravel road after dark. The car had not been run for a month, started just fine in that cold on 6 volts. The A, and early v8's had a wimpy 3 brush generator with a cutout instead of a regulator which required you to manually move the third brush to increase out for a long drive at night, then turn it back down or cook the battery dry. Your 51 has a 30 amp system with a regulator that will easily keep up to the load of lights and heater, no improvement required. The A in snow...happy new year, and yes I'll go for a drive on new years too !
