Johnnydidd
New alternator, 1 wire, 12.9 volts when not running, running 12.3 volts, no output. Do you think its the alternator?
I had a new 1 wire alternator that I bought and used it for mock up,then stored it on the shelf for a while afterwards.Maybe a year and a half or so untill I was ready to use it.When I installed it, it wouldnt charge.I called a friend who owns a alternator shop and told him about it.He told me that I needed to "excite" the field and then it would be fine,I did as he suggested and its still working fine 6 years later.The problem is I cant remember exactly how I did it.I can remember the jumper wire and paperclip I used but thats about itIt may be worth a try.As others have suggested I have to rev the engine to about 750 rpm before it will charge
Bill
X2 Here is a link!!Should always go a 3 wire over those 1 wire jobs..
