It may never read zero, even with a 100% battery charge level. The root of the problem is the 10SI design 6V alternator conversion. There is only ONE 6V regulator currently available for the 45 year old Delco design alternators, and it has a whopping high 7.7V set point with NO time-taper and NO temperature compensation circuitry. TERRIBLE!
As a point of reference, there are a dozen or more 12V regulators for the Delco 10/12SI. The lowest has a 13.2V set, the highest, 14.8V. Your 7.7V on a 6V system is like having 15.4V constantly fed to a 12V battery. A 12V battery would cook to death in less than a year, boiling even in the winter if it had a 15.4V feed! Light bulbs will have the life of a popcorn kernel. Many original (Delco made in USA)10SI regulators were designed to start cold with 14.6V out, for about 20 minutes to recover the loss from starter cranking, then as the underhood temp came up, they went down to about 13.2V. The 6V regs stay high, no temperature compensation circuitry.
Now add to the problem the peanut size (2" diameter) pulleys sold with the 6V perversion alternators. You have the full 7.7V output even while idling! Generators never charged at idle. I remember my mom's '51 Buick and all of grandpa K's Caddys. Everybody's "GEN" dash lamp glowed a little at idle. Your amp gauge often showed discharge 'till 10 mph. The repair manuals for old external 3 section 6V regulators (those big rectangle black boxes on the firewall) spec'ed either 7.10 or 7.15V as the set point, + or - 0.05V. Later, the 12V genny's were spec'ed at 14.25V. I repaired and adjusted plenty on a Sun generator test bench.
So why are the 6V regulators set so brutally high? To make the dumbass general public happy. 99% of all 6V vehicles are occasional use only. When you start them up, the battery is likely 1/3 or more down, and they are driven only an hour or less. The wiring to their lights is long and rotten, causing loss. They (the dumbass public) thinks an alternator is only 'good' if your lights get way brighter with the motor running, even if the battery is 100% and it's 100F outside.
The REAL answer is a 7.2V regulator set point for people who drive regularly and often at night with halogens and good wiring. This is possible, but would require either modifing (tricking) the existing regulator with a zener and a few other components, way beyond the skill level of most, or making a new limited market regulator that would be way too expensive to compete with the junk that is now sold. The only other fix for you is to (gasp!) go to 12V so you can run an alternator that has proper voltage set and control for daily driving. I have two A's- My 40B is original generator, my 160B is 12V with a denso alternator that is NOT a one-wire conversion P.O.S.
