mrtexas
Yesterday I posted a question about why my ampmeter would not 'excite' when I started the engine and revved it up. Several folks suggested my alternator is likely the problem.
This morning I tested the alternator with a voltmeter and found that when I started the engine, the voltage dropped. This usually indicates a faulty alternator. So I pulled a spare (new) alternator from my parts pile and installed it. Same result!
So I took both alternators to my NAPA store and asked them to test them. Test result: both alternators work just fine. Yikes!
So I'm back to square-one. There is nothing wrong with my alternator, and apparently nothing wrong with my ampmeter (I tried three ampmeters, which yielded identical results: very slight discharge).
So why is my system (12 volts) discharging when the engine is running? I have no clue. Everything worked fine before I took the car out yesterday to give it some exercise.
HELP!
Did anyone suggest you charge the field on the alternator? If you let a one wire sit around too long it won't charge because the field loses it' magnetism.
Touch a hot wire to the field wire and it will resume charging. A three wire has juice to the field all the time I think. I bought a perfectly good $200 alternator for $25 because it wouldn't charge. Worked fine after exciting the field.
