juke joint johnny
My pickup has a 12 volt negative ground alternater on it.Think it's a 3 wire one out of a ford van Put on by a previous owner .
I always close the tap and run the gas out of the fuel line before I switch it off
Last nite I forgot to turn the ignition switch off ,and closed up the garage for the nite .
So in the morning I can't find my key's because there still in the switch . by this time the battery is dead .
So I charge up the battery and the coil was not burnt out it started OK
But the alternater does not seem to be charging . So my question is,
Could the switch being on all nite have burnt out something in the alternater??? might be time to go back to the original generater!!!
thanks in advance for any help
John Cochran
John Cochran
