Alternate Ignition Switch
thespoiler
I am building a speedster with a wooden dash. I am not using a pop-out switch. Im using a pull out-push in switch. Im using basic Model A wiring, 12 volt, negative ground....My question is where do the two wires(red wire to coil and armored cable to distributor ) that go to a pop-out switch now attach ? ...Thanks
Just hook the armored and red to the switch, one on each terminal. No ground.
Bob
I would connect them to each pole of your switch and nix the ground on the switch. This is the same configuration as the stock switch.
