DosCoupe
I just got back from the Heartland Nationals in Des Moines and discovered some serious tread wear on my left front tire. The odd thing is the wear is on the inside tread and the center of the tread is really worn. The tire pressure was 24 psi so I don't think that they were overinflated. Although the air temp was about 95 degrees on the way back.
One more thing, I have about 8 ounces of those dynamic balance lead bb's in the tire to help with the balance.
If anyone has some clues as to what is happening, I would be interested in your experience.
I need to set the toe in at about 1/8 inch according some of the old time rodders from around here, other than that I don't know what to do.
Thanks in advance for your comments.
DosCoupe
DosCoupe
