BobR, Where did you get the ball valve cutoff? I have not installed my pump yet and all my work is done on my back in the yard. The thought of gas down the arm is unpleasant. A good leakproof cutoff is what I need to have when changing the filter. JPL
Here's a page with the valve I used. I need to tell you that I changed out the plastic filter with a metal, NAPA # 3031, fuel filter for obvious reasons. I also insulated the filter with a piece of thin rubber mat from the frame. Secured it with tie wraps around the filter. I didn't like metal to metal. Also, this week I changed out the metal NAPA filter after 2 1/2 yrs and the plastic ball valve worked as it should. Saved a big mess!
https://www.ebay.com/sch/i.html?_fr...Off+Valves+Clamps+Briggs+&+Stratton+&_sacat=0
