allen Well-known member Dec 1, 2011 #1 Hi two questions one what is the right pressure for 21 inch I read all about 30 inch which looks to be 70 psi, this beings up my second question how did they use that air pump to get 70 in the old days must have been a work out HA ha thanks al
Doug Money Senior Member Dec 1, 2011 #2 My 21 inch wire wheels take 35 psi. The wood rimmed tires are the high pressure ones.
redmodelt Well-known member Dec 2, 2011 #3 That would be the 30 inch tires would get 65 LBS and the 21 inch tires wood or wire get 35 LBS.
BUBBAS IGNITION Well-known member Dec 2, 2011 #4 They made a dual tube air pump for those 60 lb tires....still would have been a workout..rbg :<)
