air - fuel mixture ?
My bad. Screwing IN the idle air screw makes the mixture RICH. Sorry for the mistake guys, I had a brain fart.
Thanks for your fabulous information and pictures. I think with that I will solve the problems. BR Stefan
...another question: I have two different needles and needle housings and I am not sure which is the right for my Tilloston, please take a look at the picture; it is measured in cm...
I am using my Model A with B Head and B waterpump; Do you think the makes it neceassary to special spark plugs?
Does this combination needs a special ignition timing???
What is the right heating value if you mostly drive in slow traffic?
BR Stefan
Hi all,
I found the main problem, the float bowl has been soft solded.
The weight of the bowl therefore was different. I should have thought about it before.
BR Stefan
