Air filters
Are there any air filters available for A engines that significantly reduce intake noise? My engine of course has no air filter, and I am thinking about making my engine a little quieter. Those air maze filters look like they may not reduce sound much. Thanks
How about one of those insulation kits for the firewall to block some of the noise? Maybe a little more under the carpet.
Charlie Stephens
Unmodified Model A carburetors have a hole above the chamber where the float valve is that runs to the outside of the carburetor. This works great unless an air cleaner has been installed that has enough restriction to cause the carburetor to run rich. (Sort of like running with the choke half on.) Modern (and modified carburetors) have the hole lead to inside the carburetor intake just upstream of the choke plate. That way the air cleaner has no effect on the fuel/air ratio.
Bottom line: Use an air cleaner with very little restriction or use a modified carburetor.
-x2
The air maze screen is about the only filter that works well with the model A motor but it has to be checked and serviced according to conditions. The dirtier it gets, the more the performance is degraded. The paper types degrade the flow even if clean.
If it was a modern car you would turn the radio louder.
The answer to your question is, no. None are available that just bolt on.
Reducing noise to YOUR acceptable level and still maintaining an efficient level of performance are design parameters you will have to deal with to get what you want.
K&N has hundreds of filter elements that will work on that application but you will have to design a bracket or fixture to hold one.
Noise reduction usually requires a fairly large unit and that works to your advantage as larger is better as far as amount of flow.
K&N has reusable filter elements that are reusable by cleaning.
