I have never seen a CFM flow rating for the paper filters. My observation has been they tend to restrict the air flow and the engine runs rich.
If you put an air filter on a vehicle that is not rated at the CFM per minute of air flow that the engine requires to run at performance RPM you will have an engine that runs rich and fouls plugs.
I ran my own calculations 12 years ago using the formulas at the K&N see link below, and 200.5 cubic engine running at 2100 rpm and selected a K&N E-3050. To date I have over 30,000 miles using a K&N E-3050 and have never had any fouling of my spark plugs.
http://www.knfilters.com/filter_facts.aspx?pkid=1448282&rw=2#SELECT
Here is a link to the same calculation on Model -A.org. The calculation on the below web site are at an engine running 2800 rpm, and the conclusion is you can use any one of three filters, they conclude any of the three filters below are adequately sized.
◦K&N offers several filters that can be used with the Air Maze housing.
Part # E-3050 is 3.5 inches long.
Part # E-9257 is 5.5 inches long.
Part # E-2040 is 6.625 inches long.
But the site make this recommendation.
“◦To provide some margin for the filter getting dirty, before you get around to cleaning it, I would recommend the 5.5 inch long length. I know it is an over kill, but I am currently using the 6.625 inch long one to allow for driving on dusty gravel roads and to extend my time between filter cleaning / re-oiling cycles.”
http://www.model-a.org/filtering_air_into_carb.html
