A-Jay
Guys, now I am an Air Compressor Newbie, I bought a used 30 Gal. Craftsman upright unit which is about 7-10 years old. I believe it was used very little. When I was bringing it home I could hear water in the tank. After getting it home I had ran the unit some up to about 80-100 PSI. Then I got the bright Idea to try to drain the tank. I thought by opening the valve on the bottom the water would blow out and make a big mess, but it didn't the water only dripped out. So my next great idea was the little brass valve on the bottom was stopped up like the lower hose drain on the Model A when I drained the Radiator the first time. So I tryed to clear it with a piece of wire, but I did not try very hard because of the pressure in the tank. I thought I might get impaled what ever that means ?
Anyway is this normal for it to only drip with pressure in the tank, like maybe a safety thing? The water was clear I was expecting rusty stuff, maybe the tank is lined. Any thoughts !
