Hi,
I have a 1932 V8 i have an oil filter to install and I have a couple of questions:
* I have located the oil pressure access behind the left cylinder head. Which access should i use the horizontal plug? I know I have to limit/restrict the oil drawn off to prevent low oil pressure to the engine what size of a restriction should i use for that?
* 2nd question I have is what is the best way to tap the oil pan for the return and where should I locate the tap? Thank you!
