Looks like I'll be eating CROW for breakfast this morning.
I stand corrected. According to the "Model A Ford Construction, Operation and Repair" for the restorer by Victor Page; Information on pages 242-249 as taken from FORD MOTOR COMPANY in their book of instructions states on page 243-244 adding or removing "BRASS LINERS" as Ford called them. The same process is used with fitting connecting rods.
This being from the manufacturer is not a point that I care to argue.
It was/is not my intention to impune the expertise/knowledge of anyone. Just trying to obtain the most accurate information. Which I now believe I have done.
Thank you, Mr. Growley.
The Guy you referred to in your post, found a set of Model A shims, made with steel in a Ford Garage one time and came to his own conclusion that is what Ford used in his Motors.
That would be like finding a NOS 18 " tire in an old Ford Garage, and conclude that all Model A's used 18" tires.
About 2 months ago, the same kind of subject came up on the Model T form. The subject was, Ford did not use shims in his rods, and mains. They said the line didn't have time to mess with shims, they just run the motors in after they were built.
So, how did they come to a conclusion like that. Well, one guy had a Ford drawing for a Model T Rod, and two call themselves engine builders, and it did NOT show the shim in the rod drawing L.O.L., so there conclusion was, Model T's did not have main, or rod shims.
Ford made drawings for every part of his cars. The reason the Brass shims were not on the Rod drawing is the shims have there own drawings, and there own part Number. DA. But, they insist not, and there are about ten of them, stick together, right, or wrong.
Brass is not the cheap metal, it is the steel, that is. Price some, some time A 8X24, my cost is about 275.00 We have always used aircraft quality Brass. McMaster-Carr has sheets, the same size, around, 50.00, but is not the same stuff we use, but it will work fine. The only thing now, that kind of brass is glued together, and has to be flamed to get it apart.
Now, for the old wives tale. The biggest reason that many people say the brass is to soft, and when tightened, makes a crease, or groove, is a person that don't know, telling other people.
The reason for the crease, or groove in a shim is because, the Guy that is using them don't know how the make two part lines perfectly straight.
Brass will not mark, if the job is done right, and brass will not compress, or mark as long as the meat in your sandwich has two flat pieces of Bread.
And thank you for your kind Post, Mr. M, who ever you are.
Herm.
