Ford Freak
I'm curious. How much will they lower a '54-'56 Ford?
Abchoppers, if you’ve still got the old springs, measure the free height. And the number of turns. I suspect the “conflicting information” comes from replacing springs that are sagging or have been cut already. You’re happy, but if we could compare the free height stock, settled, etc. the next guy would have better info to work from. Might save something from having to drop them a second time to add a spacer.
My bird came with fairly new, low milage springs. I cut them once to get the car level (a lot of aluminum parts and headers on the bird). Then the Aerostar’s barely lowered it. Which was ok, I did it for the variable spring rate.
They are variable rate so the windings are tighter one end, which way do the go?
Tight end up or down?
