dmsfrr
Saving 'extra' parts? I sold that Aerostar 15+yrs ago so I thought it was ok to let the takeoff springs go in a garage sale two moves ago....
dmsfrr, if it comes off the car, it goes in a box in storage. I want to be able to put it back stock if I ever want. No cutting on my baby!! That's why I'm going to put a stock 6v harness in. I've been told and read that it will support a 12v system with no problems. Rowen
Until this '55 T-Bird is back on the road with most of the bugs worked out I'm not parting with any extra or leftover pieces. I'm even getting multiples of some things it's missing so I'll have choices of which parts to use.
Yes, the wire size/gauge for 6v systems is double the current capacity needed for 12v. Just use the proper 12v sized fuses and in-line circuit breakers for protection of 12v devices.
I'd think if you use 12v to run any original 6v motors it would be safer to start out using the fuses/breakers a 12v ('56+) would have had in case of any problems, fuses are cheaper than replacement motors. Some/most(?) 6v motors work ok on 12v as long as you're careful & don't overuse them.
